"Fake weld"
"Fake weld"
I need a suggestion on a method how to create a "fake weld" for presentation purposes without creating the whole construction all over again just to get the desired appearance. The original file is an assembly created from parts prepared as separate segments for production. Now I need a copy of the whole vehicle frame/chassis as a visual presentation unit (file) for rendering, animation, etc. Attached an image of the segment that is supposed to be joined.
RE: "Fake weld"
http://www.storyofstuff.org/
RE: "Fake weld"
Dan
www.eltronresearch.com
Dan's Blog
RE: "Fake weld"
You will probably have to create an in-context solid using a sweep, or extruded solid/surface.
RE: "Fake weld"
Thanks.
RE: "Fake weld"
