Rotation around axis/construction line
Hi
Haven't been able to find anything about this.
Is it possible to (in an animation) to rotate a part around an axis (reference geometry) or a (construction) line in a sketch?
Thanks in advance
dixib
Thanks in advance
dixib
RE: Rotation around axis/construction line
If you add a camera that is targeted at your desired axis feature then key a rotation of the camera I think you'll have it.
The animation is happening inside a room, where the parts are placed on a table. From there they are moved up in front of the camera, where I wish for them to rotate (one by one).
Rotating the camera in this situation would make the room spin around, which isn't desireable.
I've ended up letting the part be stationary.
