Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I love the structure of the site. You start at the top, and drill down to what you want. Maybe I've been using Unix too long... :-) "
Geography
0512261595 (Mechanical)
11 Dec 11 13:37
I have a confusion. The question is if a solid pin is inserted in a pressurized chamber(5000 psi) with both ends sealed, as shown in the attached picture  then how much force is required to pull the pin back. will pressure have any effect on resisting the pulling force. kindly help
byrdj (Mechanical)
11 Dec 11 13:50
Homework?
depends, the simple answer to match the simple sketch would be no.(till the retracting end enters the fluid boundary)
If a real situation, then the seal design and fluid may cause the pin retraction to be harder with pressure verses without
Cockroach (Mechanical)
12 Dec 11 8:08
No, there is  net force inrease from the pressurized chamber. The ends act equal and opposite the pressurized vessel since pressure acts in all directions over the seal ends with equal force.
The required force is simply twice that required to overcome drag of the sealed ends. Given the typical elastomer squeeze, then it is quite simply static coefficient times normal load imparted from your seal element, twice of.
You gave a word problem, therefore a word answer.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
ornerynorsk (Industrial)
12 Dec 11 12:20
One thing to note is that you may have a projectile situation as well as rapid decompression once one end of the pin clears the seal in one side of the vessel.
MintJulep (Mechanical)
12 Dec 11 12:34
When one end of the pin clears it's seal this thing simultaneously becomes both rocket and cannon.
Walterke (Industrial)
14 Dec 11 4:50
I wouldn't stand in the way of the pin when pulling it out if I were you.
NX 7.5
Teamcenter 8
Close Box
Join Eng-Tips® Today!
Join Us             Close
