why is this sketch not fully defined
Ok i cant move the circle but it shows as not being fully defend i cant add any relation's they over define the sketch so what do i do thanks
RE: why is this sketch not fully defined
Select the circle and the Top Plane and add a parallel constraint.
Even though the circle was drawn while being parallel to the Top Plane (or in the X-Z mode), the constraint isn't automatically added. I don't know if that is intended or a bug.
Not defined because it's in a 3d sketch. If it were based on a plane it would have been fully defined at that point (coincident center and radius).
