Power transmission vibration damping
Long story short, we have a transmission system that has a vibration. Decision was made that we need to get it back in service for now until there is time to do a proper rebuild and find the cause. This trans box is Al with high low ranging and a single 3ph motor standing vertical on it.
We need to isolate and damp the vibrations from carrying into the rest of the machine. Frequency was tests to swing from 40-110hz in our operating range. We did not have good calibration to give an amplitude this is a vibration you can hear and feel but certainly nothing sends you running for the E stop.
I was playing with some steel plate and seemed to be able to get about 30-40% out by contacting the motor up top. I do not have specific experience with damping and not sure if we might try a hand in a fluid device as sort of an active damper or if mass is king here? We are a bit limited on space but can fit some Lead in there but don't have any on hand any the moment.
RE: Power transmission vibration damping
If you go the latter route then some sort of flex coupling or hydraulic coupling provides the best shot at first time success, although I agree a big lump of lead in the right place can work wonders.
If you want some idea of a measurement based approach then you might have more luck on http://www.eng-tips.com/threadminder.cfm?pid=384
Cheers
Greg Locock
Even 100 Hz is pretty low. Sounds like this -
http://www.youtube.com/watch?v=mejO0hV_w80
You might also stiffen the overall structure to raise the resonant frequency, which may solve the problem if you don't have any excitation frequencies in that range.
However, 40 - 110 hz means that you've got a heavy mass on a relatively compliant spring. Have you tried rubber isolators for how it's mounted? Or some other type of vibration-absoring material?
Engineering is not the science behind building. It is the science behind not building.
I have already used some rubber isolators and YES, they do help quite a bit but I am wondering about combining mass damping with the rubber isolators to get the most effect. Because the motor is standing up on a pedestal so to speak, unsupported other than the C face mount bolts, it is allowed to vibrate.
Have you verified that it's a motor/transmission problem by removing the drive belt and running the motor speed up and down?
