Compatible engine for komatsu FD 25 - 10 forklift
I need to find an equivalent engine for komatsu 4D95S-W type engine, which is used for Komatsu FD25-10 Forklift. I received some informal advice that Isuzu C240 engine is compatible. Could somebody help me?
RE: Compatible engine for komatsu FD 25 - 10 forklift
The motor mounts, fuel and electrical interfaces, exhaust, and accessory drive locations may be, and almost certainly will be, different.
See if whoever told you the Isuzu engine fits can provide a photo of one installed in a forklift like yours, and a list of parts you'll need to buy to make the change.
Mike Halloran
Pembroke Pines, FL, USA
You also have to consider the potential change in capacity. If this tips over and someone gets hurt you could be held liable due to a non-factory approved modification.
I also agree with MikeH on the bell housing, but I would definitely check the dimensions first. Forklifts are pretty tight for space and they may well use a non-standard housing to gain a little room.
ISZ
