Weld cracks joining A544 tube to A269 304
We have an application where we join a 16ga 304 1.375 od socket elbow to 16 ga wall 1.375 od tube. Both start as seam welded product. They are both supposed to be A269 which has worked fine previously, this is a low pressure heat exchanger, fluid approx 250 deg fh.
Now we have encountered elbows which were A544 and have had resulting cracks in the a544 product. not at the welds but right next to the weld region. There is also some mechanical stress at the connection point.
Would anyone have some reasons why the A544 has such a poor mechanical result. Any ideas would be greatly appreciated.
RE: Weld cracks joining A544 tube to A269 304
ASTM-A554. Thank you.
The problem with A 554 tubing is that this material can be supplied in a cold worked condition with no nondestructive testing required. This is tubing for general purpose so you get what you pay for when ordering.
You may have a bad batch of mechanical tubing because you have cracks seen visually. Now my question is have you confirmed these as cracks or could they be surface imperfections? Was the A 554 tubing evaluated by an ASNT Level II examiner?
1. High levels of cold work and residual stress, could lead to tearing of the parts when welded
2. What about chemistry? It is possible that the fitting has a chem that results in hot cracking.
3. defects from the forming could be giving way under the stress of weld solidification.
Plymouth Tube
