Deep draw and tap to form female thread
I know it is pretty common to form a boss in sheet metal that is then tapped.  For instance in say 1mm thick steel to produce a boss that might be 3-4mm high that is then tapped M3.
I want to use this process to put an M20 female thread into a 10 or 12mm thick plate, achieving around 16mm of thread engagement.
Is it possible?
Cheers,
Ian.
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
RE: Deep draw and tap to form female thread
Pierce, extrude, and express tap is possible in mild steel, certainly.
What material did you have in mind?
How big a press have you got?
Mike Halloran
Pembroke Pines, FL, USA
Raw tonnage and tool strength are the only limiting factors.
Thankyou for the positive responces, at least it can be done.
Material is just mild steel
I have found some theory in an astm or asme  manual but the formulas fall over for such thick material
Would this be design by trial and error?  Where do I start?
Ian
