VFD CREATING TRANS NOISE AND VIBRATION?
We are battling some odd whining noises and vibration in a machine tool. All issues have been isolated to the motor/trans assy which incorporates one motor standing vertically with a heat shrunk gear going into an Al gearbox with straight cut gears to provide 1 speed ranges. There is a total of 3 gears in the trans plus the one mated to the motor.
Vibration can easily be heard and felt and is making it into our part finish. Has been this way for the 3yrs that we have had it but has not seen to got any worse. Vibration amplitude seems to be strongest from the motor but our test devices have been unable to pinpoint the exact frequencies and amplitude but fair to say with our testing that it is in the 40-100hz area. Seems to increase with motor rpm and presents vibration but not as much noise in low range.
Drive is an old Magnatek open loop drive. Drive is likely 15yrs old. Never had a single issue with it though. We do have our monitor go whacky every time the spindle accelerates, which we still cannot pinpoint.
http://www.youtube.com/watch?v=qQ9pWDc3hyY
I did not have an audio recorder on hand so I grabbed the camcorder. Please excuse all the background noise. There is also an audible thump on decel that we just cannot put our finger on. Sounds like a belt thump. Has done it for years.
Any help or ideas would be appreciated. We have been in the trans once looking for this ghost and surprised to find a rather nice looking trans. Gears look great, bearings were in good shape but we could not really test them.
RE: VFD CREATING TRANS NOISE AND VIBRATION?
It is all about the PWM waveform delivered from the drive. Google PWM and drives to learn more.
The standard remedy is to increase the carrier frequency, aka switching frequency. By doing so, you move the vibration up in frequency as well as moving the whining sound into a frequency range that can't be heard.
Look in the inverter's manual how to do it. Or get your supplier on site to do it for you.
What drive is it? I may have the procedure in a manual on my shelf.
Oh, yes. You may have to make sure that the higher carrier requency is allowed. You sometimes need to improve cooling or something.
Gunnar Englund
www.gke.org
http:/
here is the manual if you care to help out. I would really appreciate it. Been fighting this for some time now. I am going to be happy and irritated if the drive is causing all of this but my gut says no.... I hope I am wrong.
If your drive is 15 years old, it may not have the abilitiy Skogsgura mentioned. It may be time to update that system and get a better drive.
"Dear future generations: Please accept our apologies. We were rolling drunk on petroleum."
— Kilgore Trout (via Kurt Vonnegut)
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
Can you hear the intermittent chriping? There is also some pretty good vibes you can feel throughout the whole machine. All rotating elements have been disengaged except the trans and motor. Same vibration in high and low range but no chirping.
1)gearbox bearing
2)coupling wear/failure
3)bent shaft
4)gear shaft/bearing
5)spindle bearing
6)bent spindle
7)gear tooth
20)motor balance
30)drive problem
I would not expect the drive to cause a random-ish chirping noise but rather a much, much, faster vibration.
Keith Cress
Keith Cress
