MPG loss with 10% ethanol---
Theoretically there should be a 3% loss of MPG when going from gasoline to 10% ethanol. I have recorded every tankful MPG for 115,000 miles. A few yrs ago our rural was required to add 10% ethanol (to buy corn belt votes), so I have 70,000 of MPG with real gasoline and 65,000 miles with 10% ethanol. ( Same driver, same driving pattern, modern state -of -art fuel inj 5.6L Nissan V8). By inspection (have not mathmatically averaged data) it looks like a change from 16.8 MPG to 15.2 MPG, or about >10% loss due to ethanol.
Is there a reason why 10%ethanol would reduce MPG by more than 3% ?
RE: MPG loss with 10% ethanol---
That is what the 3% loss mentioned in the OP is about. The additional 7% is the question.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Seriously, a variable such as listed by dgallup sounds likely. A change of tyres can be significant. A change of brake pads or even accumulated dust or corrosion may have resulted in minor brake binding
Pat
for site rules
The EPA is supposed to run tests on additives and is that not what this is?
OK, its a mandatory requirement in some areas and because it is likely to be more widely used than the many additives and after market bolt on goodies like "fuel harmonic dingbats" , surely more pressing that it is properly evaluated and reported.
JMW
www.ViscoAnalyser.com
JMW
MS
That can only be answered by making a series of trials, with all controlled variables held constant. The results can be statistically analyzed to determine the "noise" in the experimental method. One shortcoming in the procedure, already pointed out by dgallup, is the observations were not randomized temporally (relative to unleaded vs E10), so there is much potential for a systematic error.
The base map tunes will not be optimised for E10, but knock sensors and oxygen sensors will react differently and attempt to modify the tune at least in closed loop. I doubt different heat of vaporisation will have an effect as it will be very small, and will mostly have its effect in the port away from intake charge temperature sensors.
Pat
for site rules
It suggests that when legislating for 10% madatory ethanol content, the legislators should also make provision for peoples vehicle sot be modified to handle the fuel.
I presume that as far as they got was that "there are no mechanical modifications required".... but no one seems to have mentioned the engine mapping.
It suggests that some of the green savings will be eroded by inefficient burn of the fuel (oops!) and if 10% is a semi-typical figure and not the 3% they first thought of, then they have a problem because a great many people may simply not bother to have their engines re-mapped.
If this is the case then I guess the legislators now have to find some way to fund remapping everyone's ECUs....without succumbing to the temptation to meddle more with the maps than is necessary to optimise efficiency.
JMW
- Steve
If nothing else, an off-optimum gas mixture relative to mapping would result in higher emissions, so the next generations of ECUs will nno doubt have automatic sensing of the mixture change and adapt the mapping to suit the mix.
TTFN
Chinese prisoner wins Nobel Peace Prize
(sorry, couldn't resist)
Tire pressure has always been "high"; 45 to 60 psig.
Can anyone suggest an easy to use (for a computer illiterate) statistical software. Real averages and std deviations could make me honest.
The only way ethanol even starts to look "green" is if the corn field work ,plowing etc, is done with solar power tractors; I haven't seen any working TX fields.
Old guy story : Oil corps used to monitor each others gasoline, Amoco would have meetings to decide if they should match (say Shell) in the Denver regeion because Shell was 0.2 octane higher than Amoco in that region.They worried a lot about "octane giveaway" like that.
Along with 10% alcohol, in the gasoline supplys, what percentage is the water emulsion, that will be displacing more gasoline, upsetting tune etc. I would say that is the major contributor to a variance in what a proper heat value calculation is and the actual measured MPG or power output. If this ethanol is so wonderful as a motor fuel and does all these nice things advertized how come the major airlines aren't using it?
Aircraft have to travel long distances without refuel and weight is much more critical, so it is the same reasons behind WW11 aircraft not using alcohol vs top alcohol cars using it, ie mpg and consequential fuel load is more important in an aircraft.
Pat
for site rules
The computers that plug into the OBDII port and report fuel consumption are only as good as the information they are provided. I have one called the ScanGauge II and it does a reasonable job of reporting mileage. It requires very deliberate refueling in order to correctly report to the unit what the car has just burned for fuel. Keep in mind these things only look at injector pulse width and fuel rail pressure (if available) along with the number of cylinders and do rough estimates of consumption based on what you tell it the engine it just burned (aka how much fuel was in the most recent fill up). If you don't fill up the tank every time and you don't do it the same way, or for that matter at the same pump, the numbers get skewed. Most of the ones also only have 1/10th of a gallon resolution. So you can't tell it you pumped 1.05 gallons, you have to tell it you pumped 1.1
If the vehicle has a non-return style fuel system where the ECU varies voltage to the fuel pump to keep the rail pressure at a desired value AND the scan gauge can't read fuel rail pressure (such as in my case) the numbers will be all over the place. Even though the gauge can read pulse width, if the ECU commands a high rail pressure during WOT and a lower one for part throttle duty the gauge gets left in the dark and is only really able to report an accurate average based on the previous tank's worth of driving.
They're nifty gadgets and I've used mine several times to diagnose problems. The built in DTC scanner it worth it alone. But I wouldn't use one and quote it's findings as empirical data. If anything I would only trust one to show me an overall trend over several tanks of fuel.
Pat
for site rules
Pat
for site rules
Reason any modern aircraft won't use it is because, of the lack of power or the increase in the amount of fuel needed to get that power.
And the reason it is used for our the motoring publics cars is, it makes our cars use more fuel. ie reduces the MPG.
Pat
for site rules
10 years ago when I was in the fuel additive game, EPA only required 'testing' of additives that contained elements other than C, H, O, (or N?). So Ethanol and MTBE were not regulated as additives, although I'm pretty sure they got scrutinized for emissions control compatibility.
An Excel spreadsheet is about the easiest way to handle averages, standard deviations, and plotting the data as well that might be useful for spotting trends that may be significant.
JMW
If it is E10, I calculate the value for money at 3% extra fuel consumption. It seems to work OK generally. Pricing mainly favours E10 here by a small margin.
I don't do accurate MPG checks, I simply zero the trip metre at every refill and get a feeling for distance travelled vs gauge movement and distance to empty and how much it takes to refill. Typically range is reduced a few miles on E10, but not so much compared to variations due to manner of use. Highway cruising is the only reasonably consistent manner of use as it is constantly at 110kph 99% of the time due to speed limits.
Corrosion is not normally an issue for E10. It certainly is an issue for E85 or methanol blends or 100% ethanol or methanol fuels unless the system is designed to handle it.
Fuel flow capacity is not normally an issue for E10 It can be an issue for E85 or straight alcohol fuels.
Tune correction for E10 is not normally an issue for E10, although how accurately that is handled might impact on fuel economy to give a different result to the 3& expected. It is a major issue for E85 or straight alcohol fuels unless the system is designed for it.
Fuel weight to cover a specified distance is greater for alcohol or alcohol blends. The more the alcohol in the blend and the lower the molecular weight of the alcohol (presuming only one OH group per molecule) the heavier the fuel load.
Aircraft will always be more concerned with weight of fuel to distance covered and with possible engine failure from using the wrong fuel where alternatives are available and there is a potential for confusion. If someone refuels a car from the wrong bowser, it might stop and cause some lost time and inconvenience. If an aircraft is refuelled with the wrong fuel. it might cause a crash. It ain't exactly rocket science and frankly I wonder why it needs this much explaining to someone qualified to be here.
Pat
for site rules
As E10 has stochiometric ratio of 14.1:1 rather than the 14.7:1 of petrol, in an engine fed by carburetor or open loop injection, changing fuels will cause it to run a bit lean.
Obviously modern engines (including the OPs) have closed loop control and will self-correct based on the signal from the O2 sensor. However, as ethanol also contains O2, could it be that this is throwing the correction off and actually leading to over-correction, causing the engine to run slightly rich and thus use a bit more fuel than expected?
Seems to me that given the fairly large sample mileages here 7% should be well outside the noise band. I would also tend to think that a nice big, low stressed engine like that will be barely getting into its stride at these kind of mileages - even to the extent that it quite likely used more fuel in the first 20 - 30k or so as it was still completing its "freeing-off". I know that I'm getting better mileage figures from my 230k mile Audi TDI than I was at 115k when I got it.
As an owner of other, older, petrol powered vehicles I'm not appreciating the other problems caused by ethanol addition such as failing hoses, loosened deposits leading to (repeated) blockages, O-ring and seal issues, diaphragm failures and so on. People are also reporting strange happenings on vehicles left standing for 2 or 3 months (winter layup) possibly caused by separation. Here in the UK we are only at 5% addition so far with 10% threatened.
Nick
Pat
for site rules
For performance, a richer mixture is necessary because of the alcohol.
I also build very high performance engines just for E85. The fuel system MUST be built for the alcohol with proper hoses, pumps that can flow enough-you need at least 60 percent more flow, etc.
The higher octane of the E85 allows higher compression, boost, etc. to make much more power. You cannot EVER go back to gasoline without major modifications. Carburetors need major modifications.
Many vehicles have "Flex Fuel" which passes the fuel going to the engine through a sensor that changes the programming for the amount of alcohol it detects. These engines have larger injectors, etc. than non flexfuel engines.
Talk by the politicians is they want E20 now.
I liked the excel comment above.
Pat
for site rules
ht
Any idea what "No 1 psi EtOH Allowance" means?
Everywhere I've been that is in the white "Conventional" areas has up to 10% ethanol blends at 99% of the pumps.
This map is more about relative strengths of lobbying groups than anything fundamental about gas formulations.
E85 is a whole 'nother case. I see at least a 10% drom in mpg, and evaluate the price accordingly. Thus, E85 is seldom a bargain.
E85 if it is actually 85% ethanol theoretically uses about 30% more fuel. It is inconceivable that tune and EMS and measurement by any competent person could reduce that to 10% unless something was really wrong with the tune for the 100% straight hydrocarbon, alcohol free fuel
Pat
for site rules
Does it then even make sense to put E85 in ones tank if we are on aveage losing 30% efficiency?
Only if you can get it 35% cheaper.
B.E.
The good engineer does not need to memorize every formula; he just needs to know where he can find them when he needs them. Old professor
Pat
for site rules
