DWGeditor vs. DraftSight
Quick question - Can DraftSight directly save a file as a pdf?  I have DWGeditor and it can do it.  I have a consultant just starting to use DS and he needs to send out pdfs to his vendor.  I was about to tell him he can do it directly using File -> PDF Out, but then I realized I was using DWGeditor to do a test.
Thanks in advance,
- - -Updraft
RE: DWGeditor vs. DraftSight
There isn't a save as pdf function in draft sight.  You can only save as dwg, dwt, and dxf.  Can you use a print to pdf?
Dan
www.eltronresearch.com
Dan's Blog
File > Export > PDF Export
