Export labels
Export labels
Export labels
Hello everyone,
I`m new here... but I hope You will can help me.
This is my problem : In function of drafting I have a draw from my model. In this draw are also some points. I used a label to mark this points and I have each point have a special number. My problem is that : I need to export names of labels. Is some tips to do this?
RE: Export labels
You must place these points in modeling with associative option.
Have also a look at point expression (but it deepend of your nx version)
Then, you will be able to see it an place label with an associative link to point number. And also export all information by using tools spreadsheet.
I hope this help and will try to send you an example.
Didier Psaltopoulos
http://www.psi-cad.com
RE: Export labels
The model which I have has orginal points. I didn`t add this points. But I need to mark them by labels. I have a lot of views and points. I know how to export points to excel but I don`t know how to export a names of labels.
