needs to solve system of 4 eqns, 4 unknowns
Hello All,
I what what I thought (once again!) was a fairly straight-forward problem to solve, but I can't quite seem to get there. I have 4 eqns, 4 unknowns. Equations are along the lines of:
sqrt(x^2+y^2) + z + sqrt((val1-x)^2 + (y-val2)) + Const1 = 0
sqrt(x^2+y^2) + z + Const2 = 0
sqrt(x^2+y^2) + z + 3*sqrt((x-val3)^2 + (y-val3)) + Const3 = 0
sqrt(x^2+y^2) + z + 2*sqrt((val4-x)^2 + (y-val2)) + Const4 = 0
In each case, "valn" is known, as is "Constn." "Constn" may consist of 1 or more values, here combined for simplicity.
I've tried a number of methods...from transforming the equations into other forms, combining equations in several ways, etc. Does anyone have a sound method for solving this type of problem?
Any help GREATLY appreciated. Thanks!
RE: needs to solve system of 4 eqns, 4 unknowns
Fe
If you are 100% certain they are correct relations then a numerical solution may be possible. This is a real 'may' though.
Fe
My bad, I mis-entered the equations in first post
sqrt(x^2+y^2) + t + sqrt((val1-x)^2 + (y-val2)) + Const1 = 0
sqrt(x^2+y^2) + t + Const2 = 0
sqrt(x^2+y^2) + t + 3*sqrt((x-val3)^2 + (z-val3)) + Const3 = 0
sqrt(x^2+y^2) + t + 2*sqrt((val4-y)^2 + (z-val2)) + Const4 = 0
x, y, z, and t are unknown. All other conditions same as before. Also keep in mind these are not my exact equations. val1, val2, val3, val4 are known.
TTFN
Chinese prisoner wins Nobel Peace Prize
See the attached. Looks like you have 8 solutions to those equations numerically.
Fe
-Const2 + sqrt((val1-x)^2 + (y-val2)) + Const1 = 0
-Const2 + 3*sqrt((x-val3)^2 + (z-val3)) + Const3 = 0
-Const2 + 2*sqrt((val4-y)^2 + (z-val2)) + Const4 = 0
reoorg 1 to give y in terms of x, chuck that into 3, reorg that to give x in terms of z, chuck that into 2 for a nasty polynomial in z.
Cheers
Greg Locock
sqrt((val1-x)^2 + (y-val2)) = Const1'
sqrt((x-val3)^2 + (z-val3)) = Const3'
sqrt((val4-y)^2 + (z-val2)) = Const4'
square all eq
(val1-x)^2 + (y-val2) = Const1"
(x-val3)^2 + (z-val3) = Const3"
(val4-y)^2 + (z-val2) = Const4"
eliminate z terms from (2) & (3)
now two eqn left so sub for x terms in (1)
plot eqn left standing against y and back sub the root(s)
for x & z
rainy day fun for op
