Tie-in of sump pump discharge to a centrifugal suction
We are installing a sump pump into a water transfer facility that will pump off the draining from water filters into the suction of a centrifugal pump. We have installed a wye strainer and check valve on the disharge of the sump which is rated to 35 psi output. The centrifugal's output is upto 65 psi, thus the reasoning for placing the tie-in into the suction. My question is, how can I determine the Sprng tension required on the check valve to overcome the suction that the centrifugal is creating.
RE: Tie-in of sump pump discharge to a centrifugal suction
You might be better served if you installed a back pressure check valve. Here is an example:
http:/
