How to get job-name from VUMAT
thread799-269244: Node co-ordinates and connectivity for Vumat.
Hi there,
I am currently working on a VUMAT for a material degradation law. To obtain better results, I want to bypass the characteristic length from Abaqus and want to get the element coordinates.
I managed to get the nodal coordinates into my routine. however, for this I need the job-name/inp-file-name to be able to access the inp-file. Does anyone here has an idea how to find out the name of the current job/inp-file?
I have seen a similar thing in http://www.eng-tips.com/viewthread.cfm?qid=269244
However, there it is not clear how the name of the input file is obtained.
Knd regards,
Fabian
RE: How to get job-name from VUMAT
Hello Fabian,
To obtain current job name you can use routine GETJOBNAME and VGETJOBNAME for Abaqus/Standart and Abaqus/EXPLICIT respectively.
Detail information how to use them You will find in abaqus documentation:
Abaqus User Subroutines Reference Manual, 2.1.2 Obtaining the Abaqus job name
To obtain current job directory you have routines GETOUTDIR and VGETOUTDIR.
Both routines are described in documentation:
And here is simple example how to use it:
CODE
! declaration section
logical :: fileOpen = .FALSE.
integer myJobNameLen
integer myDirLen
character*256 myJobName
character*256 myDirectory
character*256 myJobPath
! statement section
! do it only once
if (.not. fileOpen) then
! call routines to get directory & job name
  call GETOUTDIR(myDirectory, myDirLen)
  call GETJOBNAME(myJobName, myJobNameLen)
! set full path
  myJobPath = myDirectory(1:myDirLen)//'/'//myJobName(1:myDirLen)//'/'//'.inp'
! open file to read
  open(unit=1005, file=myJobPath, status='OLD', action='READ')
! change file flag
  fileOpen = .TRUE.
end if
Bartosz
Small update, myJobPath shold be:
CODE
myJobPath = myDirectory(1:myDirLen)//'/'//myJobName(1:myJobName)//'/'//'.inp'
Bartosz
Hi Bartosz,
Thank you very much for your post. That was great help!
Many thanks!
Fabian
