ChroMoVan Material Specs
I have a part drawing for a roughing cam dating back to 1945, and it specs out a grade of steel that I've never heard of before: CROMOVAN. I assume that this name stands for an unofficial steel grade containing the alloying elements chrome, molybdenum, and vanadium, among others. It is heat treatable accoring to the requirements listed on the drawing. Unfortunately I have no data sheet for this grade, and the heat treater has never heard of it before either. I already checked Matweb with no luck.
If anyone has it, could they provide a link to a data sheet that lists this grade? Information regarding chemistry, material data, heat treating criteria, etc. are what I am searching for. Any help that you could provide would be appreciated. Thank you.
Maui
Maui
RE: ChroMoVan Material Specs
Maui
www.EngineeringMetallurgy.com
http://www.varcoprecision.com/tools.htm
http:/
Thanks for your help!
Maui
Maui
Maui
Have a good one on me.
If you you could describe the end use of the component it would help in ascertaining which alloy would be best for the call out.
