Section line [Add Segment] NX8
Hi
I have a question about "add segment" in existing view using NX8.
Why appear double letter in section cut line when apply "add segment" in section line?
When I worked with NX3 to NX7.5 in application drafting all views didn't show this configuration.
Some of you know how can I disable this configuration?
Thanks in advance
Tom
Thanks in advance
Tom
NX 8.0.0.25 64bit
RE: Section line [Add Segment] NX8
I found the answer
1) Select "Section lines preferences"
2) "Settings"
3) Toggled bar, change JIS STANDARD for any other style ANSI Standard, ISO Standard, ISO128 Standard or GB Standard.
Ready!
Best regards
Tom
NX 8.0.0.25 64bit
