Thin walled concrete vessel under compression
I have a thin walled circular tank buried underground. There is no positive connection between the lid and the top of the tank, so its essentially open ended. I have worked out the compressive stress in the wall. Can anyone give me an expression for the bucking capacity of the wall? Much of the literature I have is related to shell roofs. I am struggling however to come up with an expression for my tank!!
RE: Thin walled concrete vessel under compression
Thanks very much. I assume the formula relavent to my case is either 02 c or 02 d? Do you know when to apply Roark or Ugural? One is essentially half the magnitude of the other.
By the way I see I sent a quite imperfect pdf printout, then I upload a better one.
It must be said that even if local buckling and -to the purpose of design intent- overall buckling in cylindrical tank or akin shells are not as conceptually different, these evaluations deliver mainly opinion on local buckling. Hence to prevent overall effects beign unaccounted...
1. A sound nonlinear analysis should be made, including if you want initial imperfections and anisotropy in the shell if any, as is typical of tanks when spirally prestressed.
2. I would introduce some comparison stress, incorporating the effects of bending and shear stress to compression force, what essentially means, an even lower critical stress than that given by the equation should be taken.
3. One must pay attention in analysis to differential settlement if any, since this has ruined a number of tanks.
4. If the tank is big and slender, even inwards pressures from wind etc may have additional say on the critical values.
