Lifting Lugs in COMPRESS
Hello All:
I'm new to COMPRESS but fairly handy with software.  I thought I was cruising along just fine until I went to proceed with Attach>Rigging/Lift Lug>Rigging Analysis and I get the following:
"Lift lugs are not in a valid combination for use with Rigging Analysis.  You may still specify a rigging analysis, but the lift points will not be synchronized with lifting lug locations."
I've got a one cylinder vessel, elliptical head, a couple nozzles, cone transition, support skirt/base ring and a couple stiffener rings.  I don't immediately see anything on the trunnion dialog box that is out of what COMPRESS will allow, Googling has turned up dry and I don't see the issue discussed in the Help literature.
Anyone know what this means?  I've attached the main file.
Thanks folks!
RE: Lifting Lugs in COMPRESS
I am not 100% sure what the question is but I'll have a go at it anyway.
Lifting lugs may involve detailed analysis of load path and stiffness... requiring separate design of lugs.
Ozgur Selmanpakoglu, PE
Greater New York Area
www.ozgurengineering.com
Thanks for getting back to me.  I'm just wondering what the error means?
