DXF creation using journal
thread561-264567: NX5 - AUTOMATE PDF EXPORT?
I used the above thread and the PDF conversion works flawlessly. I've also tried to use the dxf conversion to provide our customers with 2D autocad prints. Everytime I run the moog_s_export_dxf_2.vb file I get a (Journal)"Error occurred in new file creation The selected template doesn't exist journal exiting" Is this a missing license or is one of the string paths need to be adjusted?
RE: DXF creation using journal
If you create a dxf without recording a journal, do you get an error?
Worked perfectly cowski, Thanks for your help. This will help out alot.
