Change in Joint Efficiency
Hi Everyone:
I have a copy of the 1956 ASME Section VIII Code. back then the maximum joint efficiency they allowed if you did X-Ray and stress relief was 95%. When did the Code Change and start allowing 100% efficiency?
Jason
Jason
RE: Change in Joint Efficiency
If it does, for some reason, then you might contact ASME (www.ASME.org) and ask. Otherwise, how would you know whether the answer was correct if someone said "It changed in 1980?" (By the way, I don't believe there was a Section VIII Code revision in 1980.)
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
I would think that it matters when repairing or altering vessels which may have been manufactured when the maximum joint efficiency was 0.95.
Also, there was a 1980 Edition to Section VIII (Div 1), but I do not know of the specific changes made.
