How to remove "Unused" & Un-found CATDrawing Links
I have a CATDrawing that started it's life as a drawing of another Product. When I go to Edit->Links I now see only the links to the CATProduct which the drawing is actually showing. If I look at the "overload properties" of some of the views there is a CATPart which is checked-off as un-"use", but it is not part of this CATProduct. When I then go to update the views in the drawing it scans the network for this CATPart. How do I remove the "hidden" link to this part completely?
Jeff
Jeff
RE: How to remove "Unused" & Un-found CATDrawing Links
So I think I'm good.
For now ;)
Even though you got rid of the link, running CATDUA would still be a good idea.
Jeff
