Help with B18 and ASTM Nuts and Bolts
Am I correct in the assumption that B18.2.1 and B18.2.2 refer to the physical size of the nut and Bolt but not the mechanical properties (Tensile Strength etc), and that ASTM A193 Refers to the Mechanical Properties but not the physical size of the nut and bolt.
And do the standards refer to each other?
Bluecat46
Bluecat46
RE: Help with B18 and ASTM Nuts and Bolts
B18.2.1 Square and Hex Bolts and Screws
B18.2.3.1M Metric Hex Cap Screws
B18.3 Hexagon Socket and Spline Socket Screws
B18.3.1M Metric Socket Head Cap Screws
You are essentially correct, B18 for dimensions, A193 for material and mechanical properties.
ASME = physical
ASTM = material
*correct me if I am wrong...thanks*
ASME/ASTM SA-193 = chemical and physical properties
ASME B18 seties = dimensional
