No corrosion rate but pitting rate is high
Good Day All
I ran a software for Hydrogen sulhpide dominant case in which the output displays that corrosion rate is zero but high pitting rate what exactly it means?? how come corrosion rate mm/yr is zero but high pitting rate??? how would I explain it considering the electrochem reactions etc.
Kahn
Kahn
RE: No corrosion rate but pitting rate is high
NACE Corrosion 2010, Paper 10332
NACE Corrosion 2007, Paper 07659
NACE Corrosion 2006, Paper 06122
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
