Marking of Flanged Fitting Designed to ASME B31.3 304.7.2
What are the marking requirements for a flanged fitting designed to ASME B31.3 304.7.2 (unlisted components)? Code calculations would be performed as required and the flanges part of the fitting would be designed to ASME BPV Code Section VIII, Division 1, Appendix 2.
Thanks.
Thanks.
RE: Marking of Flanged Fitting Designed to ASME B31.3 304.7.2
