Can not non-uniformely scale a solid/sheet
i have tried and tried to
give a expansion rate x .016 y .016 and z .023
and it will not do it
tried on a solid no go
tried on sheets no go
exported out sheets as a igs brought them back in NO GO
Please help....
I do injection molding that requires 2 differnet shrinks for the material...
Dont understand
Please help....
Dont understand
RE: Can not non-uniformely scale a solid/sheet
Using NX 7.5 I had no problem performing a...
Insert -> Offset/Scale -> Scale Body...
...using the 'General' type scale and applying different scale values along the X, y and Z axis.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
I always used the scale through the
transform option.
I went ahead and used the Insert -> Offset/Scale -> Scale Body
on a simple solid (support post) and it worked using the scale body
The part i need to shrink was a solid from PRO_E.
tried it on that and it failed. It is a solid
Message told me that I had a face fail.
Do i need to rebuild the solid???
Thank you. I didnt even think of scale body
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
Heal didnt work for that part
Went ahead and found the problem area fixed it and
scale body did work gave me my different shrink rates.
The question I have is that this part has been a solid
from the the word go and i used all kinds of
solid functions. NX told me
it was a good solid.
So, why did it find that little face problem that I had to rebuild, only when I used scale body?
it has been a good solid for all fuctions
just not for scale body operation???
Thank you very much for help!!!!
John R. Baker, P.E.
Industry Sector
Cypress, CA
Thats what the problem was on that solid
I had to fix a 3 sided rad at a intersection
of 2 ribs.
This is the first time I have seen this
Forum and it has been a great help..
Thank you John
