NGL's & LNG Processing
Hello Everyone,
I'm working with a peice of software that creates a bottom up estimate for a LNG Regasification Terminal. That software gives me the option to process the LNG (Remove NGLs & LPGs). I'm just curious when a terminal recieves a shipment of LNG, what components are in this gas? From previous research I thought NGLs and LPGs were removed prior to Liquefaction? Would I need to remove these items again, during regasification?
Thoughts?
Thoughts?
RE: NGL's & LNG Processing
rmw
Usually we just liquified an specified natural gas wich means that you dont need to reprocess. But if your LNG is "as produced" like rmw said definetely you gonna have to pass through a natural gas process unit.
In short, its necessary that you put the properties and composition of the feed stream available to the users inserts their data.
There are a couple of facilities in the world that have the ability to do the gasification and LPG/NGL treating in one plant (and I think there are three processes that have been designed specifically for this).
