Frame generator
Frame generator
Frame generator
Hi, I have created a simple mitered frame (see attachment), now then what I want to do is place a workplane midway thru upper section, what i thought the best was to edit that section, expand in the browser click on endplane to find what the parameter is in this case its d14, ok so i make this visible, then go to create new plane from endplane and type in d14/2 which i thought would put this in the mid point, therefore if i change my frame that workplane would remain on the center....not so d14 does not appear to be the overall length, so what is parameter d14 telling me? Thanks in advance
