need help to determine twisting of angle with an applied force
I am looking for help to determine how much an aluminum angle will twist. The aluminum angle is 6061-t6 material 1/2" wall x 4" legs x 35" long. 1" from the bottom, one leg of the angle is secured to an inmovable object. 1" from the top of the other leg 30 pounds of force is applied at a 8" radius.
The question is how much will the angle twist
RE: need help to determine twisting of angle with an applied force
Go back to your text book, calculate the modulus. You've got all the other values.
That doesn't help at all! It's 1/2 inch angle 6061-t6 aluminum (not iron) leg thickness on a 4x4 angle. Ad the point is that I can't find a standard formula for torsion for an angle section.
Then theta=L*M/G/J
This is first year undergraduate stuff from your structures lectures, if that helps you to find it in your textbook.
Cheers
Greg Locock
theta = 3TL/(Gbt^3) ... b is the length of the flanges (8" in your case).
I had already approximated the answer using theta=L*M/G/J but that is really an expression for round solids.
I am under the impression that theta = 3TL/(Gbt^3) is for thin section materials but I'll try it and see if the resule is reasonable.
in future, if you know the basics i think it helps limit the -ve comments if you say so. maybe "should i use 3TL/... here ?" rather than "what should i do ?". the former implies some knowledge, the latter implies none.
