how to view/use hole centers or construction lines?
so i've got this snowboard rack that i need to layout/markup with some #8 machine screw holes (with countersink for tapered wood screw head) - two on the end of each stretcher to fasten them to the uprights - 8 in total.  I also want to layout 8 more holes on the stretchers themselves.  I've got some center holes marked in the sketches..but they're not visible when i activate the hole feature so i can properly place the holes?  why is this?
i'm also wondering why i can't extrude the 4 spacers i've got sketched on the back of the stretchers into a solid . . . . i can only cut?
RE: how to view/use hole centers or construction lines?
Make the sketch visible first, or share it.
I can extrude all objects in the sketch, can you be more specific?
You should make sure your sketches are fully constrained too.
