Choke not working
Choke not working
I've constructed a circuit to charge a capacitor bank. A choke is in series with the 12V secondary of a transformer (pre-bridge rectifier) to limit current to about 5mA. The choke is 5.75H, 330ohm, which, at 60Hz, should have an impedance of about 2200ohm, right? 12V/2200ohm=5.4mA.
However, the 400uF of capacitors are charged in the first few cycles, instead of about 10s. Additionally, when I replace the caps with a 100k potentiometer, the current is definitely not limited to 5mA as resistance is decreased.
I measured both the inductance and resistance with meters, so I know the choke isn't defective.
Also, the active current limiter I use (2 BJTs, 2 resistors) as an alternative to the choke works as designed.
What is going on here??? Thanks for your help.
RE: Choke not working
Gunnar Englund
www.gke.org
Where did 10 seconds come from?
A 12 V choke with a 330 ohms resistance seems to be a very small one. My bet is that the core saturates heavily. Use a "better" choke. One with a larger core.
Gunnar Englund
www.gke.org
One thing I had previously dismissed was another bridge rectifier coming off the secondary, prior to the choke, which supplies a DC bus for control circuitry. Schematic is attached. (The zener diode is actually a 3-terminal voltage regulator; capacitor is after regulator)
I can either lift the charging caps from ground, or change the first rectifier to a single diode.
Thanks for everyone's help!
Gunnar Englund
www.gke.org
The same is true for the positive half-wave.
Looks like you have to separate those two circits.
Gunnar Englund
www.gke.org
Reminds me of voltage multiplier circuit based on Bridge rectifiers isolated by caps in ac feed .
( just spotted zener (D9) is really a regulator comment )
