Move libraries to server
We are moving from a single user setup to a single license in a client/server setup (two users). How do you move the libraries from the single machine over to the server? What folder/files etc.
Thank you for your time and help.
Cy
Cy
RE: Move libraries to server
Look in SYSTEM OPTIONS under FILE LOCATIONS.
Make sure that any of the files here that you plan to "share" are located on your server, not your C:\.
Then make sure all your SolidWorks PCs are set-up the same.
Be aware that SolidWorks searches these file locations in the order that they're listed.
So re-order them so that the most likely location is listed first.
I've been told that this speeds things up a bit, but I admit that I'm skeptical.
There may be a few other files here-and-there that you'll need to set-up likewise, but I'm sure this will be a real good start for you.
Sounds like you just became a CAD Manager - you poor fool
"Where oh where are you tonight? Why did you leave me here all alone? I searched the world over and thought I found true love. You met another and, phbbbt, you were gone."
Hee Haw
Cy
Scott Baugh, CSWP
credence69@REMOVEhotmail.com
http://www.3dmca.com
http://home.insightbb.com/~scott.baugh/
*When in doubt always check the help*
Cy
Don’t forget to put your templates “D1.drwdot and D1.slddrt” on the server also. We also put the bomtemp.xls file out there in a write-protected directory. Then copy it to C:\Program Files\SolidWorks\lang\english\bomtemp.xls when changes are done.
Bradley
Cy
