How to increase the coefficient of friction for flexible PVC
Hi Guys
I was hoping a few of you might be able to help me out.
I have recently developed a new product that incorporates an inflated PVC bladder (rotational molded). I need to increase the grip levels (i.e. increase the coefficient of friction) when in contact with laminate flooring.
Does anyone have any information on what PVC additives / composition improves the grip? or could point me in the right direction?
Thanks in advance
Thanks in advance
RE: How to increase the coefficient of friction for flexible PVC
My first choice would be to leave the formulation as is and add an abrasion step after molding.
I will look into a filler however I am not keen to increase the abrasion level of the material as it could damage the flooring. I would like to change the 'stickiness' if possible. Do you know what additives would be best?
Chris DeArmitt
Plastic & Additives Webinars
Training the Fortune 500 since 2003
www.plastictraining.com
