Publications @ Assembly Level in V5R20 SP4
I'm having issues with the publications not understaning there reference and when I create link, they are green diamond links. There are even parameters that won't sure they are published until I open them in new window. I NEVER had any issues in R18. Anyone else having issues or is there a fix I don't know about.
RE: Publications @ Assembly Level in V5R20 SP4
Publications still work the same in R19 & R20 as they did in R18.
The green diamond symbols in your referenced elements mean that you have copied & linked geometery, but not with publications. (stuff that is linked with publications will show a blue-green P symbol)
The issues you are having are probably due to having different Tools+Options set, compared to how you had them set in R18.
which release are you using?
and thanks for the powerpoint - very helpful to understand the problem!)
There are alot of threads that explain Publications, if you just do a search.
Here's one: http://eng-tips.com/viewthread.cfm?qid=195969
