Hydraulic flush pipe question before plant commissioning
Dear Sir/Madam
The process is describe below:
Slurry from PTA rotary vacuum filter feed drum is fed on a flow rate control via RVF pump to rotating pressure
filter.Separation of solid purified terephthalic acid from water-soluble impurities is performed in two rotary filter
stages in the continuous drum filter type A/B.Filtrate is pumped to reslurry tank by RVF Filtrate pump . The gas from PTA RPF separator is sent through PTA RPF separator condenser and mist separator to PTA RPF gas compressor  where gas is compressed from 3barg to 7barg.
I have several question about how to flush the pipe before this PTA plant commissioning (the question is in my attached pdf fie)
Thank you very much for your time and kindly help.
RE: Hydraulic flush pipe question before plant commissioning
A blast from the past; I used to car pool with D. Meyer who invented the system.
I don't remember any particular problems with cleaning new system at Amoco (who developed everything to do with PTA). This sounds more like a question/problem for the engineering company / construction contractor. There is some clause like "ready for operation" somewhere in the contract.
