Repair Slip on Rase Flange (B16.5)
Can we repair Repair raise face of Slip on Rase Flange (B16.5)?
If yes, Code reference?
If no, Code reference?
Thanks in advance.
BPVN
RE: Repair Slip on Rase Flange (B16.5)
WHAT kind of repair is needed on your S.O. flange? What's the ASME rating on this flange?
The question was regarding the possibility of repair of the raised face of a standard flange (eg, Slip-On Flange Raised Face). The answer is yes, repair can be conducted on any rating flange raised face, in accoradnce with the above referenced standard.
Cheers,
gr2vessels
Becaue is is a S.O. flange I would guess it's either 150# or 300# rating at best, and if it's under 12" in size, I'd suggest is cheaper to buy a new one and replace the damaged one.
