Spline Cad Needed
Spline Cad Needed
I have a spline to create for a customer which will be EDM. I have an older copy of Machinery's Handbook I could use if need be. Does anyone have a spline creator that will create dxf. or dwg splines? Any help would be greatly appreciated. Thank you!
Spline Data ANSI B92.1-1996
Teeth 17
Spline Pitch 12/24
Pressure Angle 30
Base Dia. 1.2269 (ref)
Pitch Dia. 1.4167 (ref)
Major Dia. 1.500 +0/-.018
Form Dia. 1.329
Minor Dia. 1.290 MIN
Circular Tooth Thickness
Max (Effective) .1309
Min (.1279)
Length of Spline 1.125 +/-.010
Teeth 17
Spline Pitch 12/24
Pressure Angle 30
Form Dia. 1.329
Min (.1279)
RE: Spline Cad Needed
Are you spark eroding or wire cutting?
If wire cutting; I'll need to know the wire diameter.
If you're prepared to pay for it; you can contact me via the link below.
Ron Volmershausen
Brunkerville Engineering
Newcastle Australia
http://www.aussieweb.com.au/email.aspx?id=1194181
