The attached flange has warning deficiencies
I get "The attached flange has warning deficiencies" advisory warning whenever I try to generate my report for the attached model. I cannot see any problems with the flange that it is talking about. Has anyone gotten this same warning? What is it refering to?
RE: The attached flange has warning deficiencies
The attached ASME B16.5 flange limits the nozzle MAWP.
This is a common warning when using pipe, as the pipe can usually take much more pressure than the flange.
That is kind of a vague warning message. Perhaps, it should say "The attached ASME B16.5 flange limits the nozzle MAWP" in the warning message. I don't know. Just a suggestion to Codeware.
Thanks for the answer fegenbush
