Batch Print / PDF
Batch Print / PDF
I'm using SWX Standard 2011 x64.
How do I batch a group of drawings to print? Also, I'd like to batch a group of drawings to PDF combined in to a single file, in a single process if possible.
Thanks in advance!
Thanks in advance!
RE: Batch Print / PDF
h
You can also search this forum.
I don't understand why you would want these in one file?
Hardie "Crashj" Johnson
SW 2011 SP 4.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
Jeff Mirisola, CSWP
Director of Engineering
M9 Defense
My Blog
Many jobs we do have 20-50 pages of drawings. Combining the PDF in to a single book makes it 100% easier (for me) to manage, email, and to file.
AutoCAD's batch utility used to run this function for us perfectly. I could batch a job, and have it print a set, and PDF a set in a single function (didn't even have to open the drawings). 50 pages would take less than 5 minutes. So far I've found that it takes me about 10x longer to do the same function in SWX. To open each drawing, print them, then PDF them....repeat 20+ times....then go back with Acrobat and combine the loose PDF sheets.
-Dustin
Professional Engineer
Pretty good with SolidWorks
SWupBB 2010 lite saves a pdf every time you save the drawing:
htt
and it's free. That eliminates to whole conversion step. It's also how I archive old revs when I change the file name.
www.softpedia.com should be accessible unless your firewall is set to block it. Then search for "solidworks"
SW 2011 SP 4.0
I can have it convert SolidWorks files into the 2012 version from whatever previous version, but that's about it.
Are there any alternatives for us non-fancy pants SolidWorks users?
(also would love to find a way to batch eDrawings convert as well)
No scheduler.
I tried to load SWupBB 2010, but 64 bit is not supported, or 2010 doesn't work with SW2011. It does not show up in the add-ins.
