Resistance seam / Fusion Welding Thin Gauge Stainless Steel
I need to come up with equipment to fusion weld .006 thick 316L SS. I have two welds to make. One is a long seam in a 28" dia. cylinder with both ends open. The other is round seams of the cylinder to slightly thicker formed heads. The heads will have an acces hole approx. 8" in dia. to allow for a backing of some kind. I am currently working with Jetline on possible options for equipment. Can any one provide additional suggestions on where or who could provide equipment to preform these welds. Thanks in advance.
RE: Resistance seam / Fusion Welding Thin Gauge Stainless Steel
