Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I just wanted to say THANKS for the forum. The knowledge I gain from your site is invaluable..."
Geography
ptoolkituser (Computer)
30 Nov 11 9:39
I have trouble in ProE toolkit with simple code :
I want to open a DRW in ProE, display it an erase it from the ProE Session.
I do this :
1. ProMdlRetrieave
==> I check the number of model in ProE Session, I get 3 models for DRW ==> ASM ==> PRT : OK
2. ProMdlDisplay(drwHandler) to display the DRW
Now, If I use ProMdlEraseALL(drwHandler), the DRW is not displayed anymore, but when I check the models in session with ProSessionMdlList and I get 3 models in session.
So I cannot understand why erasing the session doesn't work.
It works if I do not use the ProMdlDisplay..
Has anyone any idea or tips ?
thanks
looslib (Mechanical)
30 Nov 11 10:23
Sound like the function is working as designed.
This is from the Toolkit user guide:
However, while erasing an active model, ProMdlEraseAll() only clears the graphic display immediately, it does not clear the data in the memory until the control returns to Pro/ENGINEER from the Pro/TOOLKIT application.
You will need another command to clear the part from session or exit the toolkit app before the memory is cleared.
Ben Loosli
30 Nov 11 11:12
thanks, so, your are telling me that there is no way to clear the proE session ?, because it work If I never display the files in ProE...
I have the same problem if I user ProMdlErase(drwHandler) and after that ProMdlEraseNotDisplay().
30 Nov 11 11:31
Don't know why ProMdlEraseNotDisplay() is not doing what you want.
Ben Loosli
1 Dec 11 8:06
I think because ProE consider DRW not erased...
Close Box
Join Eng-Tips® Today!
Join Us             Close
