Why Place MMC in Reference Datum when tolerance is in RFS?
I see this so often and I wonder the purpose of placing a reference datum at MMC when the tolerance is shown in RFS.
Let's say, as an example, we have a profile of a surface tolerance of 0.2 mm referencing primary datum A, secondary datum B (RMB) and tertiary datum C (in MMB). What is the purpose of having a datum in MMB when one must actually measure the profile tolerance on a CMM? I know that it is legal (nothing in the standard stating otherwise) but what is the value or purpose?
I can see when one has a profile of a surface tolerance of 3 mm and the secondary and tertiary datums are at MMB, one can utilize a checking fixture with the outer and inner profile tolerance boundaries shown on a checking fixture but a tolerance of 0.2 mm??
In another situation, one has a positional tolerance of a diametrical tolerance zone of 0.3 in RFS while the secondary and tertiary datums are at MMB. Shouldn't the positional tolerance also be reflected at MMC or should both the positional and reference datums be reflected at RFS/RMB?
I have always been blown away with the application of MMB on the reference datums while the tolerance is in RFS but this may have something to do with my background in measuring rather than designing.
Maybe some of the Designers here could help me out on this one.
Dave D.
www.qmsi.ca
RE: Why Place MMC in Reference Datum when tolerance is in RFS?
It really depends on where the bonus come from, the first exapmle that comes to mind is calling out a tapped hole pattern to clearance holes. The general traditional definition of tapped holes says they do not work MMC so. I know people do not like it but if we go by function and not gaging, we would default to RFS. I believe gaging is not done on the majority of manufactured parts.
Frank
When you are talking about tapped holes, I believe that you are thinking about positional tolerances at MMC. If your drawing called out a pattern of tapped holes in RFS and then referenced the secondary and tertiary datums at MMB, now there is a problem.
If the holes are in RFS and datum were also in RMB, no problem. We could measure the tapped hole location (using a checking plug in each hole) simulating the pitch diameter.
Dave D.
www.qmsi.ca
Thanks, Yes, I was and I was not aware of this as a "real" problem. I admit I have never had to measure these, thought. I have never seen anyone advocate blind MMC on threads, though it is pretty clear the shop wants them. There are always caveats, to engineers that means to be safe use RFS.
Frank
On the profile control, I completely agree. I always tell my trainees that "It's legal, it's just not useful, so put your profiles at RMB". When asked if it's ok if they put MMB with a MMC on the profile, I explain that MMC isn't legal ... it's like saying "check where the actual surface is by running the indicator (cmm, etc.) at the MMC" ... you just get air for the most part.
As for position of a threaded featurea at RFS with MMB, I see it all the time. It's almost like they're saying "get the SPC data", then let it shift around. Typically, RFS isn't needed for these, though as Frank said, "to engineers, that means to be safe use RFS." As for gaging (gauging) threads, I don't advocate the use of pitch cylinder; in any case other than one or two holes, the cost of the plugs and the usage time is prohibitive for cost. I strongly urge people to look at using major diameter for male threads and minor diameter for female threads. Several international studies have now concluded that there is no significant nor reproducible differences in the results and it's a lot faster & cheaper. For reference, Sandia Nat'l Lats did some studies in the '90s, and DIN (I think it was DIN, or the German National Standards Institute) around the same time frame. I've heard of at least one other study more recently, but I can't recall the source. Pretty much the same results from each.
The larger problem is that designers typically don't know enough about manufacturing and inspection to make good choices about modifiers, and typically manufacturing and inspection don't know enough about the design and function to understand the design intent and why the specific controls and modifiers were selected. As a result, I see too much "fiddling" and selective interpretation. Design "previews" with cross-functional teams is the answer but most companies don't understand this, and only get the groups together in the "review" stage, when it's too late.
Jim Sykes, P.Eng, GDTP-S
Profile Services www.profileservices.ca
TecEase, Inc. www.tec-ease.com
I see both all the time and although it is legal, it is not practical and, to me, reflects that the Designer does not understand its meaning.
So, to sum it up, on all profiles, the datums should be in RMB. One cannot measure a surface that is allowed to move. The part should be stationary.
As far as positional tolerances, if the tolerance has a MMC modifier, then the datums may also, but not necessarily, be in MMB. The datums could be in RMB and one could still measure or gauge the part. If the positional tolerance is in RFS, then the datums should also be in RMB. Having the datums in RMB just doesn't make sense since we are in a measuring method only.
I do agree with both Frank and the assessment on threaded features.
As GD&T trainers, we should not reflect drawings that are not practical but I have seen them.
Does this makes sense to you?
Dave D.
www.qmsi.ca
On reading your OP, Dave, I think you agree that this is OK. Your question is particularly about the tertiary datum being MMB, right?
John-Paul Belanger
Geometric Learning Systems
I have to respectfully disagree with this statement. There are also other methods of verifying profile than probing the surface by CMM. You can for instance scan the part without touching it, so the part will not move during inspection. You can use optical comparators too. Having datum references at MMB enables to adjust the part (best-fit alignment) to fit into boundaries defined by profile tolerance zone. Of course I agree that using MMB concept should be done based on functional requirements, but I would not arbitrarily say that this is poor practice in case of profile tolerances.
As for positional tolerance I can even imagine situations when specifying tolerance value at LMC with datum features at MMB makes practical sense. So again I would be careful with such statements.
Thanks for your input since this has bothered me for quite a while. I do agree that you are simulating assembly by having the 4 holes as a datum at MMB. If the actual profile of a surface tolerance is large, say 3 mm, then I can see having a checking fixture with the outer/inner boundaries scribed. We can move the part for the best visual fit.
Now, let's say we have a tolerance of 0.2 mm, we would not have a checking fixture here. I know that if one took it to the CMM room, the datums would be set up in RMB.
As far as a secondary reflected at RMB and the tertiary in MMB, wow, that is a problem.
I think that I would take back my original conclusion and say that there may be times when a profile of a surface could reflect the secondary and tertiary datums at MMB. Most of the time, it is not practical. Any Designer applying MMB on datums when we have a profile tolerance should be able to justify it in some manner.
Thanks again.
Dave D.
www.qmsi.ca
You stated "I have to respectfully disagree with this statement. There are also other methods of verifying profile than probing the surface by CMM. You can for instance scan the part without touching it, so the part will not move during inspection. You can use optical comparators too. Having datum references at MMB enables to adjust the part (best-fit alignment) to fit into boundaries defined by profile tolerance zone. Of course I agree that using MMB concept should be done based on functional requirements, but I would not arbitrarily say that this is poor practice in case of profile tolerances.
As for positional tolerance I can even imagine situations when specifying tolerance value at LMC with datum features at MMB makes practical sense. So again I would be careful with such statements."
Yes, I have used optical comparitors in my past but only on very small parts since we explode the view 20X. Yes, we could make templates too with the inner and outer boundaries shown. If the secondary and tertiary datums were holes, one could scribe in the MMB in, say, the 4 holes and jockey the part around to get the best fit. This is the use of a checking fixture rather than actualy measuring the feature though. I do agree with you here but this is a special case.
If the part is large or reasonable in size, then we do have a problem with datums at MMB. The part must be stationary to actually measure the feature.
As far as positional at LMC and the datums at MMB, I can see that. Having the positional tolerance in RFS and the datums at MMB, is not practical. We want to check the actual centre of the features and the datums can float at MMB?? The datums would be taken at RMB and then the centre of the features confirmed.
I take back my blanket statement but Designers should be able to justify why a datum is reflected at MMB while the feature is measured at RFS.
Dave D.
www.qmsi.ca
Maybe the Tec-Ease tip will somehow help:
http://www.tec-ease.com/gdt-tips-view.php?q=135
Yes, the Tec-Ease Tip confirms what I had stated. We could use MMB on datums with profile of a surface if it is to be confirmed on an Optical Comparitor sometimes known as a shadowgraft. It is also stated that it cannot be confirmed (very difficult) using a CMM or most other measuring equipment.
The application is quite limited. If you can somehow make a checking fixture on either an optical comparitor or checking fixture, then it can be used. Otherwise, it does not apply.
Thanks for the info.
Dave D.
www.qmsi.ca
Positional tolerances in RFS should be referenced in RMB and not MMB. We cannot measure the centre of a hole that is not restrained. We will obtain an actual position of the feature using measuring equipment such as a CMM.
Positional tolerances in MMB can be referenced in either RMB or MMB. In both cases, a checking fixture is best to confirm this requirement. When we have the reference datum at MMB, then a cylindrical pin would go into the feature of size or inside the boundary. If the reference datum is RMB, then a tapered spring loaded cone would locate in the feature of size or enclosure. A translation symbol (revision 2009) should be placed on the tertiary datum as applicable.
Using a CMM to measure the above is not recommended since, as Jim stated, most CMM software does not address datums at MMB. This method is OK when the datums are shown in RMB but not MMB. Usually, the CMM Operator would simply transfer a RMB to the datums which isn't quite correct.
Back to Profile of a Surface since this created the most controversy.
If one had a requirement of Profile of a Surface 0.2 which defaults to a +/- 0.1 about the true profile. If we actually measured this surface, we could get an actual reading of, say, +0.06 and - 0.09 which is not outside the requirements. It appears that we have satisfied the Profile of a Surface requirement.
We can only use MMB on a datum in conjunction with Profile of a Surface when one is confirming the requirement using a checking fixture. The checking fixture or template could be used in conjunction with an optical comparitor (Shadow Graph) on small parts or other optical measuring equipment. If the Profile of a Surface tolerance is large enough (say 3 mm), we could make a visual checking fixture with the outer and inner boundaries scribed on the surface. The part can jockey on the datums shown at MMB until we get the best fit. The only result would be OK or NOT OK since checking fixtures are attribute gauges. We will not obtain actual measurements.
Checking Fixtures used in Profiles - Usually Profile of a Surface is 3 dimensional with the primary datum as the mounting surface and in our case, the secondary and tertiary datums are features of size (per 2009, can be a surface also). The checking fixtures described above are visual and are only 2 dimensional. The fixture does NOT confirm surface perpendicularity to the primary datum. It is possible to have the Profile of a Surface requirement deemed OK with the visual checking fixture but the surface is not perpendicular and could actually be out of tolerance. This checking fixture does NOT address all the requirements of Profile of a Surface. Should we use a checking method that does not address all the requirements of Profile of a Surface? If not, Profile of a Surface should be referenced in RMB only.
Thanks guys for your help on this.
Dave D.
www.qmsi.ca
With the comment I made re CMM software not recognizing/addressing MMB/LMB, it doesn't make it inappropriate necessarily, but it does mean that paper plots must be done manually to address the datum shift. It's another step that most users don't recognize needs to be done.
Where you have "defaults", I'm thinking that you mean "roughly equates to".
Re datum modifiers on a profile control, I think that the paper plots mentioned above may still be applicable, though I haven't done this yet. I will keep that in mind for future consideration as time allows.
Your comment that Profile is a 3-D control maybe comes up short. Most Geometric controls are 3-D, with the exception of straightness, circularity, profile of a line and circular runout on a nominally cylindrical surface offset from the axis.
Your observation re projection method inspection is dead on, and should only be used for shallow depths otherwise you get ghosting (parallax?) and other issues.
Whenever we actually measure a feature, it must be held in some fashion or restrained. Whenever we have a datum shift coming from the datum referenced at MMB, the shift is manually performed using a checking fixture, template or some other attribute gauge. If we use a CMM, as an example, we still would set up on the datum as if it were in a RMB (restrained) and then the size of the datum feature is "somehow" accrued into the tolerance of the feature. Most CMM software that I have experienced does not have this capability and the few that do have it, I wonder about how the programme was developed and how appropriate the results are.
I mentioned "default" in the Profile of a Surface since the tolerance defaults to a range of of a bi-lateral tolerance, half above and half below the true profile.
I stated that most Profile of a Surface is 3D and I think that is true. If we use profile of a surface on 3 planes that are co-planar similar to a flatness requirement, is that really 3D? I think that it is more 2D so I think my previous statement is correct.
Thanks for your comment.
Dave D.
www.qmsi.ca
This is a very interesting thread. I strongly disagree with some of your statements, but I know that there are many others who would share your position. You have brought up some very good points of discussion.
My main issue is the underlying theme of the inspection method driving the design. To me, your statement that "designers should be able to justify why a datum is reflected at MMB while the feature is measured at RFS" has the tail wagging the dog. If the fit and function of the part makes datum feature shift possible, then the designer should reference the datum features at MMB. Inspection always has the option of inspecting the part as if the datum features were referenced at RMB, and not making use of the datum feature shift.
I agree with the others that it is fine to have a profile tolerance with datum features referenced at MMB. Or the secondary at RMB and the tertiary at MMB. If that's how the part fits, that's what should be specified.
Dave, I definitely agree with you that specifications like these can cause us difficulties in inspection. There are a lot of things in Y14.5 that are gaging-friendly but measurement-unfriendly. It might be easy to get a pass/fail result with a gage, and very difficult to get a repeatable numerical value with some other method. This is especially true for datum features referenced at MMB. Most CMM software still does not handle this very well. Some softwares can do the required constrained optimization, or "virtual jockeying" if you will, but most cannot. Some softwares have limited functionality, in which they can best fit patterns of holes with Position tolerances or groups of surfaces with Profile tolerances, but not both at the same time.
All of this is assuming, of course, that our intent is to optimize the GD&T to maximize tolerances within functional requirements. If our intent is to optimize the GD&T for simplicity of inspection or to mesh with a given inspection method, then a lot of things will be different. What if we know that the parts will be made by a vendor that only has calipers and mic's available in their shop - should we just specify plus/minus tolerances in that case?
Should "they can't inspect that" be a valid reason for not specifying a particular functional requirement? This is definitely a can of worms.
Evan Janeshewski
Axymetrix Quality Engineering Inc.
www.axymetrix.ca
ASME Y14.5-2009 does not get into inspection methods or application in most cases except in the forward stating that GD&T should reflect the function and relationship of the features. Sometimes, the standard does try to reflect a practical point of view.
Here is an example.
Section 4.8 Datum Features (page 57 of 2009 edition) states "However, a datum feature should be accessible on the part and of sufficient size to permit its use. Datum features must be readily discernible on the part." This appears to state a practical perspective when utilizing features as datums.
I agree that GD&T should be driven by the Design or utilization of the product --- BUT --- it should be practical. Having Profile of a Surface with the secondary and tertiary datums at MMC is not practical unless it can be confirmed with a checking fixture or gauge of some sort. Even with that type of gauge, one does not confirm all the requirements.
I disagree that the person running a CMM has an option of applying or not applying the datum shift. There is nothing in the standard stating this option. We do it but it is wrong. It simply means that there is no way of fully confirming the requirement as it stands.
Many, many years ago, we used to call the people in design "Ivory Tower Boys" because some of the designs just were not practical. Over the years, Design personnel have integrated with Manufacturing and Quality to work together as a team to make a robust part at the least cost possible. If the design is not practical in a certain area or a design could be changed to facilitate assembly without compromising the design integrity, it was changed.
I was a Quality Consultant in the automotive sector and involved in Design Review. I always remember the philosophy at that time and it should be prevalent today. If the feature cannot be measured, it should not be on the drawing. That was a practical approach.
Dave D.
www.qmsi.ca
There is a certain baseline element in your last statement. However, that's a blanket statement rather than a finite one; I have come across many parts which cannot be gauged and should not be gauged (aerospace, communications/electronics, others). The reality is it all depends upon the industry, and upon the individual component. Still, if western companies want to survive and hopefully thrive, they need specialists to come together on previews rather than reviews and get things right before ink meets paper.
Frank
Drstrole
GDTP - Senior Level
Frank
Most of us seemed to agree, in other discussions here, that the use of actual "gages" is limited (I know the auto companies use them, they make millions of the same part!). I have the same problem with those who believe I should not be able to use concentricity, if you want to check it as runout OK but if it does not pass don't bother me until you check what I actually asked for, ISO coaxiallity.
Frank
Good thoughts from a design perspective but placing a requirement that is beyond the scope of our present state of the art in industry doesn't help anyone. We can always say that we did our job and it does meet the standard and I agree that it does, but it still is "pie in the sky".
I guess that we could also have a positional tolerance of 0 in RFS referencing datums at MMB. The datum shift could give one the actual calculated tolerance if it could be performed. That, I believe, also meets that standard but is it practical??
Thanks for your comments and, obviously, other people agree with you on this one.
Dave D.
www.qmsi.ca
I mean noting against you personally. You are right I am looking from a design POV, I understand that. I also have tried for years to understand why the standards are not followed and I think this is an example of how it happens, people say what is the point if they can't use it anyway. I feel there is a greater purpose gained solely in being able to express what is needed and you saying: "I know what he wants, the best I can do is this" and we acccept it at that. That is the best we can do, currently. I also feel things change and to limit by what we can do now is narrow sighted.
Frank
I have always stated that having MMB on datums meets the standard. It is certainly not wrong applying it just as it is not wrong utilizing concentricity. Is it desirable? practical in all applications?
I really hope your company encourages Design Review since a lot of my thoughts would come out there. Sometimes there are more than one way of achieving the same result but design intent and integrity is of the utmost importance.
I remember quoting to do training in one company that produced one off parts - atomic generators. The Engineering Manager said that he didn't want anyone to learn anything about MMC. Everything here is RFS. I think the Manager would have a heart attack if he ever saw MMC on a drawing. That was their culture as I am sure that your company has a design culture too.
The reason I started this thread was that I was at a ASQ meeting (American Society for Quality) recently and the topic was GD&T. I just wanted to see how the trainer presented the subject although I am certified in GD&T but never took a course. He used a canned computer files and I noticed some of the drawings had a Profile of a Surface with the primary, secondary datums referenced in RMB but the tertiary datum at MMB. I knew feature wasn't measurable as shown in the FCF.
I wanted to stimulate a discussion on applications of GD&T that are within the scope of the standard but could cause concern on the shop floor.
Thanks, again, for your input.
Dave D.
www.qmsi.ca
Interesting discussion. But I feel the need to comment on the statements that profile tolerances with MMB datum feature references aren't measurable and that their use should be questioned or discouraged. This, combined with other misleading statements like "we cannot measure the center of a hole that is not restrained", is sending the wrong message. The addition of an MMB reference does not instantly make gaging the only option - these things can all be measured. It may be difficult and time consuming to make the measurement, as is true for many geometric tolerances. But there is nothing that is fundamentally unmeasurable.
If it can measured with RMB references, it can be measured with MMB references. The difference is that the relationship between the datum features (and thus the toleranced feature) and the simulators (and thus the datum reference frame and tolerance zone) will not be fully constrained. This does not mean that the part is not restrained or that there is some sort of moving target or instability. It means that different "candidate" relationships are possible, and therefore that different candidate measured values are possible. Finding the best (i.e. smallest) measured value involves optimizing the relationship between the feature and the tolerance zone, within the applicable constraints. This is true for simpler characteristics like Flatness as well, it's just an easier optimization with the simpler geometry and lack of constraints.
Specifying a datum feature at MMB brings in the possibility of datum feature shift, in which the datum feature can shift (translate and/or rotate) on its simulator. Datum shift is easy to work with in a pass/fail hard gaging context, but it presents special challenges when numerical measurements are desired (especially if you want repeatability). Simply put, any degrees of freedom that are available to "jockey" the part on a pass/fail gage must be optimized to get the best possible measured value. This optimization can be done on a physical holding fixture by trial and error - jockeying the part around on the fixture elements to try to get the best measurement. Or it can be done mathematically (virtual jockeying ?), by collecting a cloud of points and fitting them to tolerance zones superimposed on the CAD model. For flat thin parts, transparent overlays can be used.
In any case, how far we go with the optimization determines how close we will get to the "ideal" smallest actual value. If the optimization is not complete, we will choose a candidate actual value that is larger than the optimal actual value. On the plus side, this is conservative. On the minus side, repeatability (and especially reproducibility) can go out the window.
This is one of the double-edged swords of geometric tolerancing, especially in Y14.5. Certain functionally-derived things (like datum feature shift) are very easy to make use of in a gaging context but can be very difficult (but not impossible) to deal with in a measurement context. Why do you think most GD&T textbooks emphasize the benefits of gaging? ;^)
Evan Janeshewski
www.axymetrix.ca
Can it be effectively measured? What confidence limit would one have in the results?
I remember having an Inspector, at one time, who would take out his pocket scale, look at the part, place the scale on it and determine that the feature was out of specification .010. Now as far as confidence in the result, that would be another topic.
Have any of the people in the forum ever taken a part to the CMM room for some sort of measurement. When you went back, the CMM Operator said the part was OK and then quickly scurried away? Why was that? Did you not brush or teeth this morning? It had nothing to do with you but the fact is that the CMM Operator did not want you to talk about his measuring method. He did not have 100% confidence in the result. As a matter of fact, maybe the confidence level was down to 50%. It was measured though.
Datums referenced at MMB are conducive to hard gauging. CMMs are, at this time (state of the art), are not that good at datum shifts. Yes, we could make a hard gauge (pin) inserted in the one hole and then start jockeying the part around to get the best fit using a CMM. Is it practical? No. Does it happen? No. Any time there is a datum referenced at MMC coupled with a Profile of a Surface, the CMM Operator sets up the part in RMB.
I will rephrase an earlier statement. I said "I knew feature wasn't measurable as shown in the FCF. " Instead, this statement should have read "I knew feature wasn't measurable from a practical or confidence perspective as shown in the FCF."
I agree with Jim Sykes on this one. While the application of MMB on datums where the feature is controlled by a profile of a surface is legal, I would also discourage it.
Dave D.
www.qmsi.ca
I do not buy it. No offence, but you sound like the only measurement equipment available for you is CMM.
MMB concept is to open the tolerances due to functional reasons and that is why it helps by nature - I believe we all agree on that.
But if somebody thinks or knows for sure that the profits of having it specified on the print do not outweigh the issues related to inspection (measurement method, availability of proper equipment, time needed for measurements etc.), it is probably better to leave them far away from the drawing. I think this is the point of Tec-Ease tip.
But one has to always remember that if he decide not to use MMB only due to inspection issues, some functional parts may be rejected - just because he wanted to make inspector's life easier.
You've been involved with metrology and CMM's for a lot of years, and I have as well. We both know what is possible, and what typically goes on. But I don't think it sends the right message to designers for us to point out certain Y14.5 characteristics and say "don't even think about specifying that even if it's functional, it's not going to be measured correctly anyway". If I were to list everything in Y14.5 that I thought was typically not measured in an optimal way in industry, it would be something like this:
-Size (Rule #1 is often ignored)
-Straightness (both Surface Line and Derived Median Line)
-Position of Slot/Slab Features
-Anything involving Simultaneous Requirements
-Anything involving partially constrained DRF's
-Anything involving datum features at MMB
-Anything involving LMC or LMB
-Anything involving threads
-Projected Tolerance Zone
-Concentricity and Symmetry (not that I'm suggesting that these be specified)
Does this mean that I should discourage designers from specifying any of the above? Stick to Flatness, Perpendicularity, Position with a fully constrained DRF, and the runout tolerances?
I agree with the main intent of what you are saying, maybe it's just the blanket statements that I object to. There are a lot of things in Y14.5 that lend themselves to gaging, and are very difficult to get reproducible and correct measurements for. Even when CMM's are used, the measurement results are often (usually?) questionable. No argument there. But there are places that have the personnel and equipment to do these measurements correctly, they're just the exception.
Evan Janeshewski
www.axymetrix.ca
Yes, I was involved in metrology and CMMs for a lot of years. I have also used chucks or divider heads on small cylindrical features to measure circular (total runout is tough) runout. I have used height gauges and templates too. That was so many years ago but I have never forgotten.
Datums at MMB are vital when we are utilizing positional tolerances at MMC and other applications. It does simulate the actual assembly operations and can be verified with a hard gauge. As a matter of fact, all applications of MMC or MMB are applicable to hard gauging which has a high confidence level and is more appropriate than a CMM. I agree with Evan that some of the result from a CMM are suspect and a hard gauge supersedes the CMM if the results differ (as long as the gauge was made correctly).
Evan - In your list of other geometrical application that are difficult to understand, there are only two that I would agree are not utilized or understood on the shop floor but that is another thread. I don't think we are discussing difficulty in understanding GD&T here. It is the questionable application of MMB on datums when the tolerance is in RFS.
Having MMB on a datum when the feature is in RFS is legal. I think we can all agree on that.
Dave D.
www.qmsi.ca
Sorry, I feel you guys are being very convenient with your objections, when you do not also object when anything is not checked with a gage then. I receive CMM reports all the time with maybe 5 or 6 points checked for the flatness of a surface or 2 point size checks, no thought at all to an envelope, without anyone batting an eye. Then you expect me to believe a concentricity check requires two directly opposed points everywhere, I am sorry I really have to call that for hypocrisy I believe it to be.
Frank
Frank
It was an interesting discussion, wasn't it? The original premise of the thread was to question and discourage the use of certain functional, legal and explicitly illustrated Y14.5 applications because measurement was perceived to be impractical. This is definitely an unusual issue to raise on a forum of this type. We usually bash bad drawings, nonfunctional specs, etc.
I agree that this type of argument can easily (and often is) extended to apply to all of GD&T. I have heard it before, from companies that want to avoid the hassle of GD&T and stick with plus/minus tolerancing. "The vendors can't measure it, so what good is it to put it on our drawings?".
If we choose to specify characteristics that can be meaningfully applied to real-life geometry to control functional relationships, these characteristics are going to get complicated. This is because real-life geometry and functional relationships are complicated! If actual values are required, measuring these (and even defining them in the first place) is going to be complicated. This is part of the deal with GD&T.
I suppose that the question comes what should be done if the functional characteristic is deemed to be impractical to measure. If the characteristic needs to be simplified in order to make measurement practical, at what stage should that simplification occur? On the drawing or in the quality plan? Do we specify functional characteristics or do we specify simpler (and necessarily tighter) characteristics for ease of inspection? I suspect that there will be differing opinions on this.
Evan Janeshewski
www.axymetrix.ca
Frank
I agree that this discussion was interesting but for other reasons. I asked from a design perspective why one would place a MMB on a datum when the feature is in RFS. I stated that it could not be checked but after this discussion, It can confirmed although quite difficult and in most cases, time consuming.
The answer that I received was that it was legal and it does simulate the actual assembly process. One can performed this requirement on a CMM with a combination of a checking fixture for the datum structure and multiple measurements on the feature using the CMM probe. It can be done. Of course, a checking fixture is best and quickest but it only is a 2 dimensional approach which profile of a surface is, usually, 3 dimensional.
I certainly have never seen an example of this in Y14.5-2009 or earlier edition where one has the tolerance in RFS and the datums in RMB. If there is an example, please let me know where it is in the standard.
I never did suggest that we get into +/- tolerances and I don't know where that thought came from. People seem offended that I asked this question. I don't know why. I think it is valid to ask about the applications of GD&T and the rational behind the application. Any of my queries would have surfaced in any design review if your company promotes that structure.
You were, at one time, programming measurements or layout on parts using a CMM. I wonder how you approached this situation? Could share your experience with us? Did you set it up with the hard gauge on the datums at MMB and then take multiple measurements and report the best condition after jockeying the part and the datums? Did you disregard the MMB on the secondary and tertiary datums and apply RMB?
The ASME standard is quite explicit at times and in other situations, conflicting. We may have visual examples that don't match the verbiage or in some cases left overs from previous editions that possibly should have been deleted but that is another thread. I never suggested that we go off standard and always promoted that the design integrity.
I think I will approach datums at MMB when the feature is toleranced in RFS that same way that I have approached concentricity in the past.
Thanks for all the input.
Dave D.
www.qmsi.ca
I gave you a star for your previous comment about using 4 corner holes as a datum at MMB. In your example, we now have a Profile of a Surface relative to the datum structure at MMB.
To confirm this requirement, one would need a checking fixture for the 4 datum holes. We would end up with plate with 4 pins on true position at MMB size. Secure the fixture on a CMM and then place the part on the fixture over the pins into the pattern of 4 holes. Secure the part on the fixture and then, using your CMM probe, zero off (obtain the center) of 2 of the pins on the fixture. Sweep the surface from the datum structure with the probe which mean taking over 20 hits. Record the both extremities of the readings.
Move the part on the fixture, secure it, sweep the surface again and record your high and low results. We can do this numerous times and the actual result reported would be the best result obtained from all the measurements and all the locations with the datum shift.
We would have great difficulty setting up in RMB on the 4 holes and would, probably, end up using only 2 of the holes. This is wrong. We need to use all 4 holes since the full pattern is the datum rather than only 2 holes in the pattern.
Using MMB in this situation would simulate assembly, best method on confirming the requirement and it is not off standard. We even accrue bonus tolerances from the datum shift. It may be costly in the case of additional checking fixture and time to confirm but I would recommend this approach in your example.
Dave D.
www.qmsi.ca
I don't know if I would say that people were offended that you asked this question. We're all friends here, I think, and we can have our reasoning strongly questioned without taking offense. You and I have locked horns on quite a few issues in the past, and we often agree to disagree. Perhaps your original question didn't come across as just an inquiry from a design perspective. It came across more as "Why would you specify that if we can't measure it?". The designers reacted with "We would specify that because it's what the function requires" and I reacted with "We can measure that, it's just difficult". I don't know of any examples in the standard that have the considered feature RFS and the datum features RMB - there may not be any.
When I was first starting out with CMM programming years ago, I was lucky enough to be using software that handled MMB datum features properly and did the required optimization. This wasn't the software that came with the CMM, it was a third-party off-line package (Valisys). It was great - the software would graphically display the tolerance zone and deviations and report a transformation matrix when it did the datum shift optimization. I learned a ton about GD&T by using this software. In later years, I worked at other companies that had simpler CMM software and it seemed like a step backward. I didn't do much jockeying on hard gages - I would usually just program as if the datum features were at RMB and deal with the occasional rejection of a good part. The datum features typically had fairly tight size tolerances, so the magnitude of the datum feature shift was generally not very significant. But I didn't suggest to the designers that they change to RMB references because I couldn't measure MMB ;^).
Evan Janeshewski
www.axymetrix.ca
I gave you a star because you proved that one can confirm Profile of a Surface referencing secondary and tertiary datums at MMB with a high degree of confidence.
We simply would use a hard gauge for the datum structure and pick up on the gauge pins rather than the part. The feature would be measured over and over moving the part on the datum gauge pins each time. One would report the best results but this is time consuming and extremely expensive. I hope that the application was a vital component of the part's function and mating relationship rather than a perimeter that had no functional importance.
I have seen the use of optical comparitors or a checking fixture with scribed lines reflecting the inner and outer boundaries but we can not confirming Profile of a Surface this way. This is a 2 dimensional check and we are confirming Profile of a Line at the intersection of the primary datum and the contour. I guess that I do challenge the Tec-Ease tip previously mentioned. If your company has design review and this example is present on the drawing, someone should ask for it to be changed to Profile of a Line as long as it does not harm the design intent.
Most CMMs do not handle datum shift well and I would also set the part up with the datums in RMB. We, both, would be confirming this requirement incorrectly. The software that attempts to handle the datum shift should be proven. We assume that the software designer is extremely proficient in GD&T but are they? Do they take the average size of the datum hole or is it the inner inscribed point? mmmmmmm
There are examples of the use of Profile of a Surface with the secondary and tertiary datums at MMB shown in both the 94 and 2009 standard. This application certainly does meet the standard but no thought is given on confirmation methods.
There are limited uses of applying a tolerance in RFS and having the datum structure in MMB but some do apply. Otherwise, mmmmmmm??
Dave D.
www.qmsi.ca
