Amberlyst 15 (ion-exchange resin)
Hi
I've to design a reactive distillation column to produce methyl acetate with Amberlyst 15 as catalyst. In this way, I need to know some information of this ion exchange resin, mainly its packing density, porosity, surface area, apparent density, ion exchange capacity...
Anyone knows this and/or other properties of this catalyst?
Thanks.
RE: Amberlyst 15 (ion-exchange resin)
VINXENSO:
  How are you!
  For Amberlyst 15 ionic resin of Rohm&Hass, I only knew a little. The little knowledge coming from some articles concerning with TAME(Tertiary Amyl Methyl Ether) reaction dynamics.
  The properties of Amberlyst 15 ionic exchange resin are as follows:
Positive base: H
Active base: 50
Particle size: 0.4-0.5mm
Density: 0.6(I don't know whether it is apparent or packed density)
Max. temp.: 120cdeg
Exchange capacity(meqH+/g dry catalyst): 5.0
Crosslinking level: 12 DVB wt%
  At last, two advice may be helpful to you: 1.Log into website www.rohmhass.com of Rohm&Hass corporation to search product specification of Amberlyst 15. 2.Contact Rohm&Hass local sales department or technical deparment for Amberlyst 15 specification. At least, while taking part in HFCS sugar project, Rohm&Hass shanghai sales representative has given me ionic exchange specification free of any charge.
hi mr vinxenso...
i also searching for amberlyst-15 properties same like you... i already write an email to rohm n haas but until now, i didn't get any reply from them.have you got it? can you share it with me? i really need it to do my design project.
thanks a lot...
This information is easy to get...just contact Rohm and Haas.  They have a very complete contacts page on their site:
http://www.ionexchanger.com/contacts.htm
If you don't get service from them, I would contact Dow and ask for information regarding Dowex M31 (they may even have a newer, better product now).  M31 will work just as well as Amberlyst 15.
Bob
Hi fizanie,
I've seen in a couple of papers that the shipping density of Amberlyst-15 is 750-770 g/l and the particle size distribution is:
Diameter range (mm)           Mass fraction
   >1.12                          0.037
 1.00-1.12                        0.211
 0.80-1.00                        0.403
 0.63-0.80                        0.242
 0.40-0.63                        0.102
 0.20-0.40                        0.004
   <0.20                          0.0003
I hope this will help you.
Best regards.
hi mr vinxenso...
thank you very much for ur information... i really appreciate it.
thanks.
fizanie
