Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...If there has ever been a justification needed for access to the net during working hours, just referring to this site should suffice. Fantastic!..."
Geography
kornbrot (Structural)
30 Nov 11 7:08
hello,
i am trying to model a beam that is (example values):
'1 pris yd 1 zd 1' at one end and
'1 pris yd 2 zd 1' at the other.
is this possible or am i wasting my time?
regards,
kornbrot
30 Nov 11 7:11
can't fint a edit button so i'll do it this way:
PS: i'm using staad 2005 if this makes any difference
SethGuthrie (Civil/Environmental)
30 Nov 11 13:09
I think you are just looking to use the Tapered Member specification. Check the help contents (Index - Tapered) for details. While the tapered member specification is often used with "I" shaped sections it can also work for rectangular shapes.
1 Dec 11 4:31
i have worked with the tapered member specifications, but have only managed to create trapeze shaped beams. i am looking to model a beam with different cross section areas at the start and end node...
regards,
kornbrot
edward1 (Geotechnical)
1 Dec 11 14:14
I have modelled several bridges with haunches at abutments and at piers. I put enough nodes in the model so I would have the members no longer than 1 foot. I would get the average depth of each member and use PRIS YD ZD for that property. That works well for modelling bridges.
1 Dec 11 14:17
I agree, modeling a series of short members is always a good solution. Using the Tapered I shape (with no flanges) is maybe a little easier, but it's limited to a tapering of the depth only, where both dimensions are changing, the segmented member approach is best.
2 Dec 11 3:51
as i have got more then 150 beams i need o model i would rather refrain from modeling them all in small sections as this would significantly increase the number of elements in the model. i will try playing with the tapered i shape some more, but it doesnt seem to do what i need.
regards,
kornbrot
Close Box
Join Eng-Tips® Today!
Join Us             Close
