broken view question
How to do a broken view in a iso view in Nx7.5. I have created a broken view- OK - but the segments can not be moved in the iso direction only in sheet csys- are broken views in iso views not supported?
regards
RE: broken view question
Generally, broken views are only supported as orthographic views.  The reality is that, at least prior to NX 8.0, Broken Views consist of a separate view for each segment which means that in the case of an isometric view, you'd have to be able to align views along some non-orthographic axis which is just not possible since views are positioned in 2D space on the face of the Drawing.  So while any one view can represent isometric space, the views themselves are objects positioned in 2D orthographic space.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
Thx John,
I have tried broken view in nx8 and all works as I expect, fine.
reg.
Uwe
