Can SA-350 LF2 be used for Tubesheet?
Dear Sir,
Our client specification states that SA-350 Gr.LF2 is NOT acceptable for tubesheet and flat channel covers. But I do not understand the basis of this statement. Can anyone explain?
Appreciate your expert advice.
Thanks in advance.
RE: Can SA-350 LF2 be used for Tubesheet?
Vessel7,
Maybe it is just a Client preference. Why not ask your Client? And kindly share in this forum if you get a reply.
For ASME VIII-1 code of construction, SA-350 Gr. LF2 can be used as tubesheet material. There's even an ASME interpretation about it...
Quote:
Interpretation:        VIII-1-89-80
Subject:    Section VIII, Division 1, SA-350
Date Issued:    February 15, 1989
File:        BC89-036
Question:    May SA-350 be used as a tubesheet material in a heat exchanger to be fabricated and stamped in accordance with the requirements of Section VIII, Division 1?
Reply:         Yes.
Thanks doct9960 for your quick reply with ASME interpretation.
I will certainly let you all know once I get the feedback from our client.
Basically, this requirement has come from an Offshore Oil & Gas operator.
If anyone has got an idea re the subject above, please share.
Thanks again.
Vessel7, some years ago I had seen a paper from one of the big E&C's (disremember who) discussing the lack of fracture toughness as measured by Charpys in thick SA-350-LF2 tubesheets. The values in the center of thickness of actual forgings were quite low. This E&C therefore did not allow SA-350-LF2 for tubesheets, and as I recall required SA-266 instead.
Your client may have similar concerns.
Mike
Perhaps a better place to post would be the "Boiler & Pressure Vessel" forum ???
