Rotation of small plastic tubes
How could I rotate small plastic tubes (sealed on one end), all in one direction ? They're 65mm long, diameter 8mm and their sealed end is 1mm thick. These tubes must be fed vertically into a machine for montage with their sealed end facing towards the floor.
I've attached 2 pictures of this plastic tube.
RE: Rotation of small plastic tubes
You might blow them into position - assuming the closed end weighs more.
Pick them up and using a "feeler" to find out which end is open/closed and flip if necessary.
Use a ramp that will shake the part off if it is top heavy.
B.E.
The good engineer does not need to memorize every formula; he just needs to know where he can find them when he needs them. Old professor
