NX 7.5 STEP Export Problem
I'm trying to export a step file of an assembly in NX 7.5 but I'm not having any success. When I import it back into a new empty model file, only the datum coordinates appear and not the parts themselves. I have all of the components in separate folders with the assembly part in a folder containing those folders. Any idea how to fix this problem? Issue is with STEP203, 214, and even IGES. Any help would be greatly appreciated. Thanks!
RE: NX 7.5 STEP Export Problem
You can also export the assembly file from within NX.
Ben Loosli
Customer defaults should have the filename being used to load your load_options file.
Ben Loosli
