Painting Galvanized Steel
We are looking to reduce cost on some parts and it has been suggested that we change from aluminum to galvanized steel on the chassis and covers of these parts.  I seem to remember that galvanized steel does not paint well.  Is this true? Is there a process to paint galvanized steel?
Steve Smith
Product Engineer
Staco Energy Products Co.
www.stacoenergy.com
RE: Painting Galvanized Steel
If you are trying to use steel for automotive underbody applications, you should use cathodic electrocoating - this is the standard process for the auto industry.
If you need an exposed part with matched paint, then you will need a multi-step system similar to what OEM's use to coat galvanized steel.
For either of these choices, try PPG Industries for more information:
http://www.ppg.com
