Compressed Air Audit
Doing a compressed air audit and they want to know the size of the leak 1/64- 1/32- 1/16- 1/8- so on... how the heck do they expect you to know what size the air leak is coming from a fitting?
RE: Compressed Air Audit
Not possible in my opinion!
What you could do is to measure pressure loss in an isolated part over time. (The isolated part could be the complete system or a part).
This would give you the average volume loss at a certain pressure, which again could give you a comparison to the loss through a circular hole with a certain diameter.
In addition to the fact that even a 1 or 2 mm hole will give you a considerable loss at a normal pneumatic pressure, I also completely agree with you.
Any loss costing money is a waste if normal sensible good maintenance, improved layot and correct equipment could prevent it. (Remember also to calculate cost of downtime, not only pressure production!)
To try a pun: Its' not the size of the hole that counts, but the amount of mony you have to put into it!
http://www
http://www.compressedairchallenge.org/
http:/
